Frigidaire refrigerator what year?
loried75
Feb 16, 2021
2
Sayre
I bought this refrigerator & cannot find any info on it , what year it is. The numbers on the plate are, FPD-144BN-R GN. Could someone please help me with this ?
FPD-144BN-R GN. <span style="text-decoration: underline;">F</span>rost <span style="text-decoration: underline;">P</span>roof <span style="text-decoration: underline;">14.4</span> Cu Ft <span style="text-decoration: underline;">B</span>ottom freezer <span style="text-decoration: underline;">N </span>1968 <span style="text-decoration: underline;">R</span>ight hinge <span style="text-decoration: underline;">GN </span>green
Had Frigidaire stopped using the little resistor thing that caused defrost cycle failure by the time this fridge was manufactured?  This is a major concern for me with Frigidaires from the early '60s, so I'm wondering if/when they stopped using this troublesome component.
Little resistor Thing ??
Hi Ralph, Are you talking about a defrost drain heater ?
A drain heater is technically a resistor of course and almost all early Frost Free refs used drain heaters.
FD was a very reliable FF refrigerator as were other major brands, problem is very few are lasting 50+ years or even much over 30 years.
The only real exception are GE Hot-Gas defrost systems, which also use a drain heater.
John L.
John, as I recall this was indirectly related to the heater and required removal of the freezer floor and/or other interior trim pieces.  I'll see if I can dig up an old thread about it.  There's more than one IIRC.
Hi John,  I found the thread, and yes it's the drain heater (seen at front left in the picture).  Much more tear-down to get at the thing than I remembered.
https://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?54668
The big problem
With the older frigidaire frost frees, is that the defrost heaters hang up and melt all the freezer plastic, so many were ruined by this.
