Hello,
I bought the Frigidaire washer pictured below from Greg M last year. This is the same model machine my grandmother purchased new from Potomac Edison in 1965 except hers was white. I finally have the time to take care of any rust or other issues before using it, but am having difficulty removing the top. I have the rollermatic repair master, but that doesn't provide much detail. My second post shows the wiring connector block where I'm encountering trouble. I'm in need of advice/direction on how to disconnect the wire block to remove the washer top.
Thank you,
James
Thank you,
James
