When I go to work in the morning in the cold months, I've been turning my thermostat way down out of my desire to not heat my apartment when no one is in it. Upon my return in the early evening, I turn it back to 66. Indoor temps usually are in the middle or lower 50s by this point in the day and it takes the heat pump a good hour to raise the temp up.
So, here's my question: Is what I'm doing an inefficient practice as the heat pump has to work appreciably harder in order to heat the space from a much cooler intial temperature that normal?
I've heard people say that during the cold winter months, they'll leave their furnace/heat pump on during the day set to whatever temperature it normally is as they believe the furnace/heat pump has to expend less energy maintaining the temperature than climbing from a cooler initial temp.
Any opinions would be appreciated.
