So as to not keep everyone in the dark, a quick update on the compressor swap on the '65 GE. That old compressor was a beast, I'm half tempted to throw it on the scale and see what she comes in at.
In the meantime, I did pick up the late model WP SxS fridge with a donor compressor (Panasonic). A quick fit up and I think I should be able to make it work in the same space with a modified back for clearance. The condenser motor blades are a just a tad too big to consider this a drop-in, so I'll have to get creative.
Same story for supporting the condenser and compressor, but that shouldn't be too tough with some aluminum angle. In the meantime, I have a new cap tube drier on the way and hopefully will be able to close the system this weekend.
One question for the experts...in converting to R-134a, what should I do about the oil charge? Both fridges were upright long enough for any residual oil to have drained back to their respective compressors. Will the PAG in the new comp be sufficient? I'm not real concerned about trace amounts of mineral oil in the GE, but wasn't sure if a little more PAG should be introduced. I'll blow out the condenser when I remove the drier, maybe see what comes out for volume. Thoughts?
