Miserable Bolts
I have the last of the GE Filter Flo's. It's fifteen years old.
We keep it in our basement for guests to use whenever we have company. Recently, it quit draining during spin. At the end of a cycle, there would always be an inch or so of water at the bottom of the drum. Consequently, the clothes were soggy.
I thought the pump was the problem. So, I bought a new pump for $75 from a local, Mom-n-Pop, appliance repair shop. The pump was purchased with the understanding that it was non-returnable.
In the process of trying to figure out the draining problem, I knocked the little plastic water shoot thingy between the inner and outer tubs.
Therefore, I had reason to remove the inner basket.
The agitator came off with no problem.
Then, like you, I came to those miserable three bolts.
Three bolts: three days.
I heated. I pounded. I sprayed the things with bolt loosener stuff.
I did, however, pound on each of the three bolts equally.
In other words, I didn't take one bolt off and then work on the next, etc.
But needless to say, getting those suckers off was a painstakingly slow and laborious process.
But do you know what? It's worth it.
For the first time in my life, I actually did a repair that worked.
And do you know what? Not only did I recover the plastic water spout. . .but I also discovered something:
I didn't need the $75 pump after all.
There was a sock that managed to get lodged down there. And it was blocking the drain hole.
So--perseverance is key. Keep pounding. Use fire.
Those bolts will come off. And you will be on the way to building self-confidence and discovering the beauty of GE's.
