Well, actually more like a need to rant.... Canyon's getting fed up with hearing about this... LOL
So, I figured it was time to get something done with that '57 GE washer that I got in fall of 2012. I knew when I got it, the machine wasn't running. Last week, I spent the week down in Ogden so that I could some exploratory surgery. The machine would simply buzz, then very quickly pop the breaker if I attempted to make the machine spin or agitate.
I tried to be logical (a big change for me...LOL) in my diagnosis. I disconnected the flexible pump coupler and tried spinning the pump manually. Suprisingly, it turned smoothly so that wasn't the problem.
Next, I tried spinning the transmission pulley in both directions to see if I could make full rotatations, simulating agitate and spin modes. Well, by golly, I could! Recall that the poor old 60 GE BOL washer tranny could be made to rotate manually to simulate spin, but not to agitate. My conclusion was the transmission may be OK.
So that left the motor... Not surprising that it may have seized up - I checked my notes on the machine and as per the grandson of the former owner, the machine had been in use until 1980 when his grandmother gave up her home. The machine sat in a damp basement until I got it.
I actually have a manual for the 57 GE washer, so there are reasonably detailed instructions as to how to remove the motor. Per the manual, the clutch assembly has to be removed in order to take the motor out.
And this is where the wheels fell off... There is a drive hub above the clutch that is held on by a pin (I guess it's a roll pin of some kind). GE makes mention of a special tool (GE part WH50X55) to drive the pin out. Now, I did attempt to drive the pin out with one of my limited punches but I don't seem to have one that is the right size....
I did some searching for the 'right' tool - I found references to a Gemline tool (model TB665 - picture attached) and a set of punches made by a company I believe was called Bidwell and Wells in Orlando. But do you think I could find the tool or specs as to the size of the punch? Nope...
I did some further searching for pin punches and what seem to be the best possibility is a set made by Wheeler Engineering used typically for gun repairs.
Any thoughts or suggestions? I will attempt to get some better photos of the clutch pin itself, if I can.
The darndest thing in all of this is that I know I need to do work on the motor for the '53 GE as well, so I'll have to get that clutch removed also....
In the meantime, I am trying not to drive myself too crazy with this dilemma!!
