GE IDA 421L Automatic Dryer
mt999999
Apr 4, 2020
16
East Liverpool, Oh
Hello all!
I posted here once some time ago about this unit. I've been using it regularly since I picked it up a couple years ago. I finally decided to open up the back and clean it out. It's been drying a bit slower, likely due to a lot of lint build up. While I was in here, it looks like the belt on the motor is just about shot... it's de-laminating. I'm wondering where, if anywhere, I should lubricate this while I'm in here, and what kind of lubrication would be best. Any tips on where to find a belt?
In one photo, I took a close up of the shaft coming off of the motor... should that round port be oiled, or does this motor not require lubrication? I have white lithium grease in a spray can as well for the mechanics and pulleys, if that's the correct thing to use on this unit. I had to de-gunk and de-lint quite a bit back here before the photos... the motor and wires/terminals were totally coated with fluff.
One additional question; it doesn't appear that the HI/LO switch does anything. Upon further inspection, it appears that the switch broke some time ago (as pictured), and I think they hot-wired both terminals to the one side of the switch like a junction (unless I'm looking at it wrong)... basically, I think they by-passed the switch so the unit is always on "high" heat. Can replacement switches be found to fit into here?
Thanks everyone!
Neat Old 1954-5 GE Dryer
You can probably get a new belt either at an old hardware store or on line.
The GE motor on your dryer is newer than the machine, so it was likely replaced at some time, I would not worry about oiling this motor they were very good motors.
You can use the white lithium grease on the shaft of the spoked pulley and its sliding shaft. You can also look at the top of the main drum bearing tube and see if there is an oil hole and add light oil to it if there is one.
The Hi-Low temperature Sw does look to be by-passed, it basically reduced the heat input by switching more or less of the heating element in the circuit, it is probably not that important the dryer will still get just as hot on either setting.
John L.
Thank you for correcting the photos! I've uploaded the failed photo again. It was just the schematics on the back as well as the sticker mentioning the motor replacement. I attached a picture of the front of the unit as well.
I picked this unit up for scrap years ago for free, but a new screw-in 15A fuse made it work again! What a heavy monster! I can't seem to find much of any info for this unit on-line... I guess they are getting rare.
Would it be particularly imperative to replace a belt that's splitting like this one, to performance or otherwise, or should I not worry about it until it breaks? The drum seems to spine fine. I plan to hang a line out this summer anyway.
Basically with the switch, I can't turn it down to low heat as it is now. Would anyone think it be safe to modify a modern light switch into it for low/high, if it fits?
I'll check the drum bearing for a spot to be greased. Thanks!
Well... It Broke
I've been using this trusty dryer since, and some how, the belts still haven't broken. Tonight, the timer was smoking when the dryer was running. It seems like two wires going into the timer shorted off of each other and melted the old insulation. I separated them, but the timer does nothing now. Yes, the circuit breaker is flipped on. I replaced the burned 15A fuse, but still nothing.
It seems to me that the timer was fried. Can this be repaired, or does anyone have a replacement? I'd hate to replace the dryer. Many thanks!
1955 GE electric dryer
This can be fixed, but you probably need a new timer or a good used one and do some wiring repair as well. A picture of the damage would be helpful.
Older electrical dryers often have problems with the heater circuit. These dryers were made for a lower voltage and when you run them on the modern 240 V that +60+ years of age, they tend to have more problems with wiring connections in the heater circuit
A lot of times if you really want to use a dryer, this old, you need to put a power relay in the heater circuit to reduce this type of failure.
John
The matching washer to this would have been similar to the one GE Robert has, wasn’t a Filter Flo model though.
The early GE automatics from what I understand spun at 1140 RPM (Robert would be the one to know), the same as a Frigidaire Unimatic.
Washer
Unfortunately, I don't think this dryer was purchased with a matching washer. I rescued it from the cellar of a SW Penna home several years back. The owner was flipping the house and listed some appliances on Craigslist as "free scrap". I suspect it was a little old lady's house looking at the contents. I hauled this heavy beast of a dryer out with a similar era speed queen wringer washer (not functional) and an old 40's gas stove. I decided to keep the dryer, one because it was horrible getting it into my cellar (by myself to boot, and I sure didn't want to haul it back out)... And shocked was I to see it in functional shape, so I put it to use! It's been our only dryer for at least 5 years.
I'll post a picture of the damaged wires on the back later. Perhaps someone can point me to a new or used replacement timer to get her going again. :)
