maytagneptune
A while ago my dad brought home this GE GUD24ESSJ0WW from the used appliance store scrap heap. The unit was dropped and needed a new lidlock and dryer timer. The original intention was to fix it up and bring it over to a rental property that a friend of ours owns but it didn't fit in the space. The old machines we took out of the rental property were a Frigidaire Gallery FL washer with a broken spider arm and an Asko Dryer on top. I have sense started liking the machine other than 2 fatal flaws with it which I was able to address one of them by swapping the console and the motor control board to match. Yesterday I found a GTUP240EM1WW. That machine was NASTY. I saw gunk inside the drum and the machine REEKED of cheap fabric softener, gunk and it had a dead animal smell. My father suspects there could have been dead mice in it. So I took the motor control board and console off of it and brought them home. I then used a cross reference tool to make sure the drive components were the same and the ones that were different part numbers were electrically the same so I swapped the boards over. I wanted to do this because the GUD24ESSJ0WW's auto load sensing almost NEVER uses enough water. And the GTUP240EM1WW had full water level control. The machine has ran fine after swapping the parts over. The only thing I hate about this machine is the first spin. It spins then stops and goes and stops and then spins up and during the fooling around. The fabric softener falls out of the dispenser and is wasted. So I just put the softener directly in the drum during the rinse fill.
