That is a strange model. It has all of the cycles, but no detergent dispenser. Frankly, I never saw a Mobile Maid with those lines with a pink interior. If it is genuine, it must have been one of the last to leave the factory with the squared front and a pink tub, but that cheap bol wash-out detergent cup does not go with the TOL machine. It went on the bol machine where the timer did not trigger the detergent dispenser. With that wash-out cup, the detergent supply would be exhausted before the main wash. Maybe one of those slow to dissolve tablets would work. Our Mobile Maid similar to this had the blue tank interior and white racks and the new style white covered detergent cup. Our first Mobile Maid with the pink interior had just one cycle and the pink detergent cup where the timer shaft's magnetic portion held the lower part of the cup in the upright position until the timer rotated into the main wash portion of the cycle, moving the magnetic portion of the shaft away from the metal clip in the cup causing the cup to drop and spill its contents. This older machine also had 1 or 2 more water changes than the later one with the blue interior which, in spite of having the Power Shower, did not clean quite as well as the older model. It was better looking with the all white cabinet and all of the excess chrome trim.
