If I remember correctly, there is a screw under the chrome cap in the center, or maybe access it from the butter compartment - its been six years since I took mine apart. The rest of the door is held together with screws and metal strips under the gasket along the edges. The old gasket might fall apart when you pry it back to get to the screws. You can buy gasket material at www.antiqueappliances.com/index.htm.
