GE Washers Exploding
whirlpool862
Mar 3, 2025
153
Columbus, OH
Some of the modern high-end GE washing machines are exploding during the spin cycle, not just Samsung. It mainly affects the impeller models. I’m even seeing it on the newer Profile units. It’s mainly happening to models such as the GTW720, GTW750, GTW680, GTW810, GTW860, GTW840, etc.
The high end GE’s I’ve been discouraging for a while, the bottoms of the tubs tend to fail over time as well. The bottom hum is made of pot metal and needs a full tub replacement to fix. So many posts on social media show GE’s that have blown up. These newer high end GE’s explode just as much as the older Samsungs did.
These machines should be recalled! (at least for the washplate units). I watched two videos where they exploded on camera, I heard a loud bang in the video and saw that the washer blew up.
Here’s an image of the reviews of their GTW500ASNWS exploding. DO NOT BUY GE WASHPLATE WASHERS. If you have one of these washplate GE washers that have exploded, you’re not alone.
If you’re getting a GE washer, get one with an agitator and buy the cheaper model.
    311.6 KB
The report references that the explosion occurred, as is often the case, when washing a (waterproof?) mattress protector. No mention of what cycle was running ... what was the spin speed.
The Samsungs exploded due to that factor as well. It’s still a thing that shouldn’t happen. I never see it on the basic GE’s nor the VMWs. I don’t see it on the latest Samsungs either.
"Last week my 2 years old Whirlpool washer (front load) model WFW94HEAWO ser #C32651933 was exploded while running (didn't had any extended warranty) called their customer service took me nearly two hours to talk to human who can listen…no positive outcome after all that next day called the repair guy and said it's better to buy new machine because it's gonna cost me way more to repair because wheel balancing had broke plus the door. Moral of the story is POOR PRODUCT, POOR SERVICE.”
Another case of a once-great American manufacturer slowly milking the cash cow until it's nearly dead, then selling out to a foreign entity and going to pot. The executives seem to think the only value is in their trademark (and their bonus packages), not the goodwill that was built over most of a century of making good stuff... The only one that comes to mind that bucked this trend is Frigidaire. I think their line is far better under Electrolux than WCI.
There were some incidents of washing machines "exploding" in the UK a few years ago, I think including some whirlpool, candy and hover machines.
https://www.ukwhitegoods.co.uk/http...ndy/2979-more-candy-washing-machines-explode/
https://metro.co.uk/2021/03/30/mums...-washing-machine-explodes-mid-cycle-14332162/
This is sadly an issue in many industries these days. Companies have no issue designing products that barely meet their performance marks. It’s called “factor of safety” for example, you want to design a chair that can hold 300lbs. Typically you would build it then with a factor of safety of 1.5 or 2.0, which means the actual chair could hold 450 or 600lbs. The issue is it costs money, “extra” money. So the beam counters and execs push engineering to narrow that factor of safety to the lowest possible to meet cost targets and still allow the machines to survive warranty.
It’s pretty awful these washers are tearing apart, but GE or Samsung don’t care, they’re out of warranty!
They will only care if and when their reputation takes a hit, to affect sales and income.
Some of the modern high-end GE washing machines are exploding during the spin cycle, not just Samsung. It mainly affects the impeller models. I’m even seeing it on the newer Profile units. It’s mainly happening to models such as the GTW720, GTW750, GTW680, GTW720, GTW840, etc.
GE has gone downhill since 1995. Since then, they've only gotten worse.
Front load washers, disintegrating, or exploding
Hi Norge999 , there is no point in reposting here say we don’t know what happened to that whirlpool washer. The user might’ve gotten something caught in the door and when it went into spin, it could’ve thrash around violently enough to break the balancing ring or something.
Yes, it is certainly possible, and there have been a few incidents of front load washers. Having catastrophic failures, the European style machines are much more likely to have serious damage because they have particleboard tops, which don’t contain any catastrophic self-destructing effects of a metal basket coming apart.
Because of the way of front load washer tumbles it’s not likely to have problems with waterproof bedding, holding water if the water gets in at tumble’s back out before it gets into the fast spin cycles.
One thing for sure the Speed Queen front loader is never gonna do a self-destruct between the thick stainless steel outer tub and the all steel cabinet and the welded stainless steel wash basket and the cast-iron counter weights. There’s not much to fly apart.
I did however, see a video one time of a 1954 Frigidaire unimatic washer that pretty well self-destructed it knocked the top loose when the balance ring self-destructed, so any fast spinning machine could possibly have a failure from time to time.
John L
Come on now... that's after the YouTube dude put a cement block in it and defeated the door switch!
...and sat it on a trampoline?
The Candy/Hover issue was reportedly "a drum production anomaly seen sporadically in a tiny fraction of drums in high-spin models."
It's all about silly, dramatic, mindless, entertainment - destroying something for amusement.
Some people are bored and need to express themselves and gain "views" or "followers".
Don't they earn advertising revenue if their "channel" is popular enough. That sort of rubbish is slightly better than the videos trying to convince people that you only ever need to use a teaspoon of detergent, or the best way to clean your washing machine is by throwing baking soda in the drum and vinegar in the dispenser.
This is the (sad) state of affairs that the world has come to these days.
You can thank the magical marvelousness of technology and the birth of the Internet.
Yes they do earn money. The internet provides tools for income as was planned with the decline of domestic manufacturing, etc. As they say, get with the program, adapt, change, or get out of the way.
All of this reminds me of an episode from Seinfeld where Kramer loaded a bag of concrete mix in a top loader. Even though I laughed, I'd never do such a thing to my machine. As long as you take care of your machine and don't put things in there than you shouldn't, they'd certainly last longer than you think. No wonder the GE T series is still alive working well at my cousin's cabin, works and cleans just fine as long as it doesn't get overloaded.
A condo that I shared in 1980 with a roomate had the washer and dryer in a hallway closet.
We threw my 27th birthday party there, among plenty of other parties like Xmas, New Years, etc.
Naturally we served beverages, and we would fill the washer with beer and ice to use as a convenient cooler.
Oh, and we put the empty beer cartons on top of the dryer with a sign - "Empty Ones Here!"
And after the party, cleanup was easy.
Because the next morning with our hangovers still lingering, all we had to do was put the washer on spin cycle to drain the water out.
Of course, checking it first for any bottles or cans, etc.
What about the recent Samsungs and GE's and even LG's that have exploded even when doing everything right? You'd never see that with the Whirlpool direct drive or Speed Queen Laundry.
Until something major in the corporate world is announced, consider GE and LG as one and the same poducts, because they are as far as I'm concerned.
