So, this top assembly from a 19323 General Electric CA Monitor Top fridge came from the scrap yard. It was seized and had all its useful parts stripped.
The General Electric CA model was used only in 1933 and 1934. They used a very low pressure refrigerant which was only ever used in these two years of Monitor Top. This Methyl Formate refrigerant will degrade with time and heat, releasing non-condensable gases into the system. This requires maintenance bleeding of the system.
The low pressure characteristic of this refrigerant meant that the compressor had a large displacement. The large size of the moving parts, compared to the small motor power means these will become "stalled," "stuck," or "seized up" very easily. This often happens from sitting, lack of bleeding non condensable gases, or from loss of the crankcase oil heater.
This is a hermetic motor compressor with the unit welded into a steel casing. The only access to the compressor is vie electrical connections to the motor's terminals.
In this video, I try increasingly forceful attempts to re-start the seized compressor.
