maytagneptune
First of all. I posted in imperial because Neptunes with serial numbers dating 1997.1998,1999 and 2000 are all turning 20 this year. Models I'm referring to are MLG2000AWW,MAH3000AWW,MAH4000AWW,MAH5500BWW,MAH6500AWW,MAH7500AWW. or any neptune with a solid door panel. The Spider Arm on the MAH4000AWQ I worked on showed no signs of corrosion are these ones coated or are these Stainless Steel?
