Heating Element for RCI-75-61
mikqiis
Jul 26, 2025
After months of digging, I finally found this site, which is the only source that has actually had any information about the range I have.
I have an RCI-75-61 range from Frigidaire in 1961, and with the dual ovens, the one on the right side needs its heating element replaced. I'm certain I can't find vintage parts in good condition, but is there a modern equivalent I can use to replace it?
Thank you in advance!
(Pic 1: full stove, Pic2: broken heating element, Pic3: working heating element from other oven)
    1.7 MB
    2.2 MB
    2 MB
I am assuming you’re talking about the bake element for the right oven, has it been confirmed to be bad does the broiler still work in that oven for example.
This was a fairly unique element, but you should be able to find a good used one on eBay or something I could even suggest places to look, but I have no idea where you live.
Both those oven liners pull out for cleaning and it’s easy to remove the bake element. It’s just screwed to the back of the pool out oven liner. It could also be the receptacle that’s bad that the element mates into when it’s pushed into place.
These were neat stoves. It should be able to be kept working for quite a while yet.
John L
Is this maybe a foreign model? I ask because I have the American model and the trim is totally different. By the way, you have the support for the Speed Heat element under the regular 6 inch element. It's the one with the little silvery insert in the center. The plug out bake element should be fairly standard for 40 inch wide ranges because they all had the same size master oven. Do you have an appliance parts store near you? If so, take the element in and ask. Do you have an old appliance store nearby? They might be a source.
