Help Help Help KD-10
dosxxpapa
May 19, 2013
169
Oregon
Just got a call from the electric motor shop, they told me that my motor is beyond repair.
Where do I go from here.
Joe
Can they be
more specific?
What exactly is wrong with it? If it needs a front bearing, they are still readily available I am sure. The rear bearing is more problematic as it was a sleeve bearing. The centrifugal start switch may have been damaged when they took it apart but should be available somewhere ad they still use them in many motors.
Hopefully they did not make it worse than when they got it from you so maybe you will have to get it back and try a better motor shop.
Rotor
Rotor is melted down, he said it could be repaired, rotor would be $900 to $1000.00 also need a new rewind and new bearings, shaft needs to be re-tooled. He can do everything but the rotor. His part would be about $600 to $700 dollars. He would have to send rotor out to be redone somewhere back east. That would be about $1700 dollars total. That's a lot. It would be better to start looking for another machine.
Joe
OH BOY!!
Was the motor just sitting there cooking itself? STIll sounds inconceivable. I guess it may be time to get it back and look for another machine like it out there to make one out of 2. JUST so you don't feel so bad, the newer style vertical motors commanded some incredible prices as well brand new. Well close to a grand too and these were the ones that would have fit the newer style Kitchenaids as well as the commercial UM machines.
Maybe you can scout around at some rest equipment companies who go in and dismantle restaurants and auction off the equipment. Maybe some really old donut shops may have had some really old undercounter um's like your KD10. Or even a closed down bar and grill. Many of the UM's were used as glass washers in the bars.
Hope you find something. Just don't give up hope.
KD-10 KD-11 KD-12 Wanted!!!!!
I know that this is a hard question. But is there anyone sitting on a KD-10 that would be willing to sell it?
Or is there anyone willing to sell their KD-11 or Kd-12?
I know it is hard to part with our machines but I could really use your help.
If you have a KD-10 that is just sitting that you would be willing to part out. It would be cheaper to send a couple of parts at a time then to ship the whole machine.
Please let me know.
Joe
Motor Cooked
Hey Steve,
I was running a load of dishes in the KD-10. I am always at home when I used vintage machines. It was about half way through the wash and I smelled it. I immediately went and shut it down and disconnected it. So no the motor was not just sitting there cooking itself. That is why I have have such a hard time that it is that bad.
Thanks Steve for all your help.
I would appreciate it if everyone would help me look for a donor machine motor etc..
Let me know.
Joe
Somebody:
Please come to the rescue with a good or rebuildable motor for Joe!
I really think he deserves it; he's proved himself a wonderful custodian of the vintage things he already owns.
If this was someone making a first post, where they asked the impossible, I'd hold my tongue, but Joe has paid some dues.
Joe, if I had one, it would be yours already.
Thanks Sandy!!!!!!
Thanks Sandy,
Your the best!!! I believe I have some friends on this site and I do believe in the goodness of humankind.
I think we can work on this together and somehow someway it will all workout. I am not ready to throw in the towel.
Something will come up.
Joe
Yep!
"....somehow someway it will all work out."
You already have the most important factors in solving this - acceptance and patience.
Could it be that a certain Packard taught you about those things, LOL?
Yes.
And so have you!!
When you go vintage, it's not an appliance it is an adventure, and I am ready for the journey...
Joe
Thank Sandy!!!!!!
Thanks Sandy for trying to rally the troops on my behalf.
I hope someone will come through!!!!!
Your friend!!!
Joe
This is bad news... But I wish you luck in your search for a replacement motor for your ailing KD-10. How strange that something that seemed so simple could amount to so much: Perhaps the issues with the motor were developing and something lost enough tolerance to cause the complete failure.
A fair warning for all members here with vintage machines: Care for your machines, and pay attention to the sounds they make. Most importantly, it might be prudent to remove the motor and have components repaired BEFORE they go bad.
BUT: I hope this song is a appropriate and keeps your spirits high during your search:
Lyrics linked below, if you need help deciphering the song :-)
http://artists.letssingit.com/the-seekers-lyrics-keep-a-dream-in-your-pocket-s6w4mrn
This Is a Job For....
STEVET!
Here's what I'm wondering, and I think stevet could help more than anyone else with the question:
First, what is the part number for the motor? And,
Second, does it cross over to anything Hobart? Remember that KitchenAid began as Hobart's "residential" line, based on their commercial stuff, and that the farther back you go, the more parts-sharing there was between the two brands.
So, if stevet could chime in here, I think it would be helpful. Even if we don't find that Hobart repair centers have an off-the-shelf replacement, it might be that we find that something of Hobart's used the same motor, and we could find a rebuildable core that way.
OK
Serial Number: 175430
Model KD-10
SPEC-4987
Motor 80307, H.P 1/4, Type-AEB-KD, PH-1, Volts 115, CYC-60, AMP-4.0, RPM-3450,
Temp Rise -50 C., Time Rating-cont.
Hobart MFG CO.
Troy Ohio
Thanks
Joe
