Stuck Timer On A Two Motor KA DW Timer
Hi Nick, is the main cam block stuck ?, or is the timer just not advancing through the normal cycle ?, it is also possible that the rapid advance motor has failed which can leave the cam block stuck in one position.
The timer motors are replaceable separately if we can see which timer motor you have, there were two different timer makers for timers for this model.
