electroluxkid
I’m seeking some help to diagnose the issue with my washing machine. Can you please review and provide some guidance? Thanks in advance!
Machine Type: Washing Machine
Manufacturer: Whirlpool
Model: WTW4800BQ0
Serial Number: C41523167
Events that lead to the issue:
-Turn the knobs to select Temperature, Cycle and Water Level
-Touch electronic fill button (to begin cycle)
-Add clothing and detergent
-Close lid
-Machine continues to fill with water as normal
-Once machine is filled the machine never begins the selected cycle. It will instead click, discharge all water and the pump runs for a long time.
-Machine stops
I’ll let some time pass and restart, or, unplug the machine, let 5 minutes pass and plug the machine back in.
Once I restart the machine it will either advance to the cycle and run as normal or drain as described above. Sometimes the machine will not advance to the cycle until the third or fourth attempt.
Thanks again everyone!
Model: WTW4800BQ0
-Close lid
-Machine stops
