Help !!!
johnny42
Mar 6, 2017
46
Glasgow
Can anyone please advise me on how to remove this gasket so that I can remove the heating element from my wringer washer. ? I have already put some lubricant on it, but it is really stuck!! (see photo)
I had stubborn heating elements on water heaters round off because they were so stuck.They never won against a hammer and chisel at a slight angle though.That's called an extreme impact  wrench and it never failed.Try that at last resort.
I would definitely take a torch and gently heat that nut that is holding the heater assembly in place. I also would try a pipe wrench if there is room for it. You should probably cut a new gasket above the nut anyway.
Thanks for the advice unimatic1140. The machine is in a real bad condition. I got it from ebay. It needs a lot of TLC. It has quite a bit of rust on it.
