here we go again folks
Non-heating Maytag gas dryer
Hearing the sound of one gas valve opening is a good sign that means power is getting to the gas burner assembly.
Do you see the igniter come on?
If so, does the igniter cycle off in about a minute?
If you see the igniter come on and cycle off that means you have a bad gas valve solenoid. The secondary valve coil is bad
Unfortunately these are hard to get now they are technically no longer available but you can probably find them out there somewhere. White Rodgers change to a more repairable valve assembly in 1984. Most times we run into these earlier me tags and whirlpool‘s. That have bad valves or bad valve coils. We just put the newer style valve assembly in the machine.
It always amazes me how much trouble we had with Maytag gas dryer‘s and GE’s for that matter, even though they use the same white Rodgers gas valve, assemblies that whirlpool and Kenmore did .
John.
it semi works to the extent
let see if I can prose this
the igniter comes on nice and strong
there is a loud click and a WHOOSH and the gas ignites
it heats
I need to time how long it heats
it clicks and the gas valve closes
need to time how long it is off
the igniter comes on nice and strong again
loud click but no whoosh no gas
igniter goes off immediately
need to time this but I think seconds maybe then the ignoter comes on but goes back out
hope i got the info straight
thankkees John
This i can fix because I can get the parts
I'll need to research the parts numbers to order the correct parts
oh here is the youtube video of the dryer
I can make a video without the front on if needed it is nor difficult to take the front off
see when and if i have to pay anything as it ia in warranty
The seller of this machine provided a warranty on a 43-46 year old dryer?
Nice!
Older Maytag dryers with this control system ran around 10 minutes, never long enough to actually dry anything with air but it made a nice additional cool down or you could fluff up some things that have been sitting in the dryer.
How long is it running on air?
Is it turning off reliably at some point?
John
Does the chime sound when the clothes are dry? If so, the electronic control unit and wiring should be good.
The main reasons for this from most common to leas common are...
Broken linkage from actuator to the tab on the switch.
Broken tab.
Tab on the switch is very loose and sloppy (requires a new switch).
Cool down thermostat contacts are welded shut (should have no continuity through the 2 terminals when the dryer is cold).
On regular permanent press and damp dry it shuts off when it is supposed to
Chime does not work because part of it is broken
but air dry continues to run on and on
I'll sit and watch it I usually do anyway because i am fascinated of the gas system
I watch the gas flame thru the access door
still finding out what does what in the heating cycle
Going to tinker with it more
now to find out about the Calypso washer in the other post I made
