Hilton 9 Washmaster
adam-aussie-vac
Dec 14, 2017
1,067
Canberra ACT
Hey guys, yesterday I went to Sydney to pick up The dishwasher that I brought, and I just noticed under its little kick panel behind two acorn nuts there is a partial sticker that says washMaster but the voltage and catalogue number are not existent as that sectional the label is missing, it also has what appears to be 2/8 of a wiring diagram, but it does indicate of what the button and the amber light are for, from my understanding, the red light is probably either power or washing, and the switch is probably the main control switch, although it looks like this doesn’t actually have a heater, and the drain solenoid works the same way of how Modern American sink basins work with the pull up stopper, although I did found out, the unusual thing is, I think that the water solenoid was replaced, as that has a metric fitting while the drain probably fits a imperial fitting better, (the fitting that was screwed onto the drain was something I bought from my local hardware store as I wanted to see if it would work, the threaded and I will probably use a bunch of American plumbing fittings to have this so that way it would drain into the sink away from the internals of the dishwasher
