masks
Hi Sarah
I've been making a few masks and have a couple more designs to try.
I have never been great with sewing, much more comfortable fixing a sewing machine than using it...
However recently I scrounged a beautiful Janome Memory craft 6000, the first computerized sewing machine, about mid 1980s.
It was desperate for a few drops of oil and a clean.
It has an amazing number of tricks - always stops with the needle up; you can press a button for it to move just enough to put the needle down (for stop-and-turn manoevres ); it has a setting for straight stitch where it starts a run with 4 stitches, then reverses 4 stitches, then continues straight stitch. At the end of that run you touch the reverse button once and it repeats back 4 stitches and forward 4 stitches to finish off. Stops with needle up...
It also has a built in needle threader which was working perfectly but has just quit. I will have to investigate.
It has built in embroidery patterns including letters of the alphabet. I love it.
Back to masks - I have been watching two youtube channels that regularly have good mask designs - "DIYCraft JP" and "Thuy Phan made with love." First is from Japan, the second from Vietnam. Both of them have designs that have an extra "flap" that fits back over the nose for better fit. You can also stitch in some reinforcing metal strip or wire though I have found that if I get the stitching JUST right then I don't need a nose wire. This is the one I particularly liked and have made a few of...
You can download a PDF and print off a template for most (but not all) of their designs.
The DIYcraft JP ones all finish of with the completed mask being modeled, then some antics from their Siamese cat. I love watching them, they are strangely hypnotic and calming to watch.
I can post pics of some of the masks I make if you would like.
I recently read that small children are finding it scary and confronting that people around them in public are covering their faces.
I am planing to make some novelty face masks that are definitely non-scary. (but still effective face masks.)
Animal faces, smiley faces and so on. A couple of them may violate copyright so I won't show them here...
My ideas are way beyond my skill, so we will see what eventuates.
