Hoover 0517 stopped spinning today :(
mbish
Mar 7, 2011
4
My beloved Twin Tub washer stopped spinning. Well, it spins very slowly, and it no longer drains. I am at a loss and don't know what to do. Any suggestions would be appreciated!
Thanks!
M
twin tub
Hi i have had the same problem befor i changed the condensator it is a long or schort thing inside the machine that provides extra power to the motor at start up or the third phase if it is an 3 phase motor in side, on the 2 phases it wil run slowly or just humm so i am 99.99 % seure that this is ur problem. there schould be 2 of this 1 for the wash motor and 1 for the pump and spin motor altenative u can test it with a ohm meter or a voltmeter if it is okay you can charge it with the battery in the voltmeter usual 9v if it is Working u schoud be aibel to chage it and dis charge is by conveting the polarity i can send pic if needed
Sounds like the valve in the pump is knackered. I had this happen to me before with my old T5090. Had wash water coming up through the spinner, although it did pump out, slowly. Prob need a new pump, or repair it.
Hoover 0517
This model has no internal "valve" like the European or the pre-1970 models (US) had, only a pinch valve that is very unlikely to give this issue. The pump has probably seized and the the spinner has water in it. DO NOT RUN THIS MACHINE LIKE THIS! You WILL cook the spinner motor. When you put the machine into "DRAIN" it opens up the drain pinch-hose. If the pump is not turning, then it will simply bleed the water into the spinner. Here is a photo of the pump assembly. You can remove the back panel and let the drain hose all the way down below the cabinet and gravity drain it. Try and turn the pump by hand, I have a feeling that it is either very tight or competely locked. My e-mail is in my profile, I'd be glad to help you with it. I will e-mail you.
-Tim
Pincher
Yup Mike, that's all it does. I think there were 2 reasons for this actually and one I think being a symptom of the other. The way this drain pump is setup, the spinner side is always open, no matter what. With the old pumps with the switching valve in the top, the plungers could get stuck or the user could simply misuse the machine and cause water to be trapped in the spinner while it is trying to run, possibly damaging the machine. This design eliminates that possibility completely.
The "effect" of the new design is that there is always an air leak in the pump. When you are trying to drain the wash tub, the pump is also sucking in air from an empty spinner, so it slows down the output by quite a bit in the draining process. It takes one of these Hoovers about 3 minutes roughly to drain a wash tub. My 0510 and 0512 (older pump design) can do this in less than half the time. This slow draining also serves a purpose as well I believe though. Since these machines were never marketed as a "family" washer like there, they were mostly relegated to apartment dwellers or people with no machine hookups. As so, many of these machines ended up being used anywhere there was space like say a bathroom or other shallow sink. The reduced drain flow meant that a much smaller capacity sink could be used to drain off the machine without the hose flying out or over-running. That's my theory anyhow, but it makes sense. The question is which was the reason they did it?
The newer pump uses the same base piece as the older pumps though, but if you think about it, they run almost twice as much as the older machines as the drain time is over twice as long. It is very rare that I find one of these Hoovers with a good pump in them. If I find one with a working pump, I will take it apart and use some light machine oil on the pump shaft and lube it up again, it seems to prolong things, but o-rings for the housing are also scarce.
Thanks
-Tim
