Hi Nat
Congratulations!!
I have a sump hose for my machine which I got about 10 years ago. They all fail in that same spot. I reckon you could improvise as follows:
Method 1: Cut off the damaged part of the hose, leave about 30 mm of the concertina section attached to the tee. Find a piece of PVC drain pipe (plumbing pipe)that fits firmly inside the concertina, I would guess at 40mm. Cut a length about 50mm, fit it into the concertina section attached to the tee so that half protrudes. Use a radiator hose clamp to secure. Use a Hoover Zodiac sump hose to go from the sump to the PVC joiner you have made and secure with hose clamps. You might have to cut the Zodiac hose to length. If the diameter of the Zodiac hose is wrong (I haven't checked) then source a hose for another machine.
Method 2: Cut off the t-piece and the concertina part of the original hose. Replace it with a 40mm or 50mm PVC drain t-piece,(which ever size fits) as you would use for a kitchen sink pipe. Place a PVC blank in one side of the tee, connect the other side of the tee to the curved rubber hose of the original, and use the rubber sump hose off a Hoover Zodiac to connect from the sump to the centre of the PVC tee. Your only hope of finding a new original hose is to chance upon a shop with old stock. I have had the PVC improvisation in the back of my mind for ages as I doubt I will ever find a new replacement.
The curved section of hose is very soft and floppy, that is normal. It does NOT mean it is rotting out. It is probably fine.
Don't bother trying the Zodiac door seal, they are totally different. The Keymatic seal has a very soft thin lip around the door opening, the Zodiac is thick and bulky.
I just might have a good used door seal if you need one. I want to keep one for myself but I think I might have two??
If anyone needs a "rubberised rope loop" spin belt, the original type, I have two or three in stock, in good used condition.
The motor has one start winding but it has a capacitor assisted start which gives it strong torque. When I had several of these machines and was chasing parts, I found a small repair shop, Sears Morton in Blackburn, who still used one for washing rags in the workshop. They had several dead machines for spares at the time. The owner was a real enthusiast for these machines, and explained that the motor had to accelerate from full speed in one direction to full speed in the other direction in 0.7 seconds. It had to be so fast so that the distributed clothes stayed against the drum and didn't drop into a ball when it started to spin.
I have just looked up Sears Morton in the Melbourne White Pages and there is no entry. I have been meaning for years to go there and see if they still have any parts, but they are probably no longer there. Sorry!
The only Keymatic I now have is missing its motor, unfortunately.
Chris.
