electron1100
Its only 35 years old i think i should pen a letter of complaint to Hoover things just dont last these days
Thanks to Paul (matchbox) i have a Hoover A3060 which over the fullness of time i have been servicing, and it works beautifully except on one thing, whilst on the 1100 spin there is an almighty clatter coming from the machine.
Initially i thought that will be heater element retaining bracket no longer attached to the tub allowing the heating element to flap about, an inspection showed this not to be that case.
However i did notice a load of beige colour stuff all around the concrete weight mounts, so after stripping out the tub i could get a closer look, and in deed the mounting plates that are spot welded to the tub that support the weight appear to have come away and the previous owner has had a go at using some sort epoxy resin to fix them in place
So i got some stainless steel nuts/washers and bolts and drilled holes and have clamped the plates on so hopefully this will stop the weight flapping around on a spin.
Here are pictures of the job starting with mouthing plates in as they were.
