HotPoint Potwasher dishwasher transformation!
maytaga806
Nov 20, 2012
694
Howell, Michigan
Hello all! So lately Ive been using my Hotpoint Potwasher dishwasher (80's GE Potscrubber) on a weekly basis We never used this dishwasher at all, it is original to our 60's home. We started using it more frequently just this month, now were using it almost every other night. Works and cleans so good! Anyway, I was so sick of the white and wood exterior and I covered all that nasty looking old style up with some stainless steel contact paper! A total transformation!
Now your probably wondering, why the heck is there a whirlpool dishwasher upper spray arm on the top rack? Well, Im in the middle of making some modifications to the dishwasher so that the top wash arm can be operated.
Since there is two extending sprayers that shoot out of the lower spray arm that's what's supposed to clean the top rack. It doesn't do that well of a job for me, and Im taking out the very top jet that sprays the top rack so that there is a direct water flow that shoots up into the upper spray arm, I just need to add a tower so that the water has a thinner pattern going into the upper wash arm to activate it. It already does well without the tower, but when I get it, it will operate a million times better!
Yes, we have well water. I have to get some iron out and clean the dishwasher, I havent in a few years. We just got a new water softener so the rusting wont be as big as an issue now once I clean it again. I also do run monthly cleaning cycles of vinegar and baking soda on an empty, hot cycle!
That is very interesting
Did you re-work the power tower so that all the water directs upward into the spray arm? I would be interested to see how that ended up working. I know Whirlpool used a tapered tower which had a nozzle / jet effect to concentrate the water stream into the spray arm (as opposed to lower velocity water which will want to separate out of a concentrated stream and not make it into the spray arm).
All in all though, very impressed with the stainless trim you added and the addition of the spray arm for the upper rack.
Adding a Full Upper Wash Arm
Very clever, keep us posted as to how this works out, the only real problem I can see is WP used fairly small holes in their wash arms since they had a filter and you may end up with blockage in this WA.
Keep us posted, I always love this kind of in the field engineering.
John L.
combo52 & william637
I just have to order the original tower that feeds the water into the wash arm. I may have to make some modifications to the rack so that it will fit considering the height and dimensions of the tower. I will post a video when its done!
