how to find tech data sheet
sel8207
Apr 19, 2013
166
naples, florida 34117
I have a whirlpool du1055xtsq3 quiet partner i dishwasher. Am having trouble with electronic control panel. Looked it up online and it says that there is a tech data sheet behind the lower front kick panel. It's gone. Was wondering if anyone knew how to get one. They have parts, owners and installation manuals online, but no tech data sheet. Have tried different reset codes, that I found online, but none of them work. I suppose it looks like a wiring diagram and entry code sequence diagnostic. if anyone know where I can get that information, please let me know. thanks for your assistance in advance. les.
control board problem
Purchased for relative about 4 years ago. used about 5 times. Moved to my house. Does not start up. I can get the drain motor to turn on, although it has no water in it. At one point, I got all the control panel lights to turn on. (although I don't know what sequence of buttons caused that to happen.) Several hours later, when I was gone from the house, it started and ran. was running when I returned. Am basically fed up the computer board driven dishwashers and washers. But if I could get it to run… I know that it has to have hot water in it, so I will put it in the house and drain the tepid water from the supply line, then try to start it. Right now it's on the lanai where I am working on it. Already ditched (tonight) the "gold" series whirlpool in the kitchen. (it's 'gold alright.) Now that one is out to be picked up by the trash man. If I could figure out the sequence to make all the lights come on to'reset' it, (the new used one) then maybe this one would work properly. (or work at all). les.
correct number
That is the correct number for the tech data sheet, but most places says that it is NLA. Oddly, Sears says 'this part must be ordered by a technician', which I thought was kind of strange. A couple of places did have it, but cost plus shipping is over eleven dollars. Well, I'll see what happens when I bring it inside tomorrow, plug it in and see if I can get it to work. thanks much. Les.
