Broken toilet seat hinge (plastic). Can't just buy the
hinge from the manufacturer, have to buy the entire toilet
seat (special size/shape) for $50. So want to try gluing
the plastic. Haven't found a definitive guide to gluing
on the net - might be out there, but searching is just so
difficult these days with all the junk.
First problem is determining the type of plastic and unless
I take it to a chemist... I have a cement that works on
acrylic, but this isn't acrylic. It's a hard, white plastic -
pretty strong but not strong enough when a 200 pound roll of
carpet is pushing against/across the seat. I would say it
is the type of plastic you would find in a 1 or 2-step stool.
I'm thinking of using either super glue or epoxy. Super
glue says not to use on polyethylene. I don't think it is
polyethylene, but there is obviously nothing on the part
that says what it is.
Any experience/hints? I have the super glue here, but if it
doesn't work, then I'm left with residue which could mess up
the next attempt with epoxy. The biggest issue is that it
broke off vertically, so whatever I do will have to deal with
shear along the glue joint rather than at an angle to it.
