How to restore really yellow pillow cases
iheartmaytag
Mar 19, 2008
4,760
Wichita, Kansas
I found some of my grandmother’s hand embroidered pillow cases recently. After years of storage they are not only yellow, but almost a brown. I washed them last night in hot water and Oxi-clean but it didn’t lighten them at all.
I am afraid to bleach them because of the embroidery work. Any suggestions of restoring these to their whiter days? I am ok with them being darker if that is what it is, I just don’t want to damage them any more as they are Grandma’s handiwork and she isn’t around to do any more for us.
Let them soak over night in this solution. I think there is a detergent out there for this. Let me check and I will get back to you. I have several of these pillowcases from my wife's grandmother, but they are white on white, and they bleached up really nice.
Here are some suggestions:
Vintage Linens: Soaks & Cleaning Recipes
For old vintage linens that are yellowed with age and need more than spot cleaning, here are some recipes for soaking the entire piece.
Notes:
Check a spot to make sure the recipe won’t damage the fabric or colors before soaking the entire item.
When drying linens in the sun, lay them directly on the grass instead of hanging them–the weight of hanging wet linens can warp or damage the fibers.
Recipe #1
1/4 cup Kosher or Sea salt
Gallon hot water
Cover piece entirely and soak for at least 48 hours. Rinse well and lay out in the sun to dry. See notes below for rinse method.
Recipe #2
In a large roaster or pot, fill with hot water and several slices of lemon. Bring to a boil, turn off the heat and add your linens. Use a wooden spoon to push down the linens until they become completely submerged and saturated with the water. Cover the pot and leave overnight.
Rinse well, wash with mild detergent and water as usual and then lay the items out in the sun to dry.
Buttermilk Soak – Recipe #3
1 Quart Buttermilk
1 Gallon Water
1 TBS Fresh Lemon Juice
Soak linens in the buttermilk recipe for up to 24 hours, rinse twice, then launder as usual.
Biz & Oxyclean Soak – Recipe #4
1 Scoop* Biz
1 Scoop* Oxyclean
1 Gallon Hot Water
Soak in the hot water for up to 48 hours, then rinse and launder as usual.
*Use the oxyclean scoop
Rinse Method
After washing linens, give it a good vinegar rinse to remove as much of the soap as possible. Use one cup of white vinegar per gallon of water. After the vinegar rinse, rinse again with plain water a time or two.
And here’s another spot treater recipe:
3/4 cup rubbing alcohol
1/4 cup water
10 drops mild dish detergent
How Long To Soak Vintage Linens?
You can soak items for a few days if they are heavily yellowed and the cleaning solutions aren’t giving you the results you want. Just replace with fresh hot water + recipe every day or two.
Bleach Stains From Old Linens
Here’s a cleaning solution for bleaching stains out of old linens, spot test first before using:
Vintage and Old Linen Stain Cleaning Solution
2 quarts distilled water
1/4 cup bleach
1/4 cup shaved Ivory Soap bar
Mix ingredients and soak item for approximately one hour.
Dry in sun.
Repeat again if necessary (you can still use the original bleach mixture you used the first time–just store til needed).
Cleaning Vintage Linens Recipe
Old vintage linens are lovely, but they can yellow in spots as well as hold stains. Here’s a recipe to help brighten things up.
Vintage Linen Stain Remover
1 Gallon warm water
2 TBS Ivory Soap (grated)
1 TBS Bleach
Mix and let sit to cool until liquid has gelled a bit. Apply to stain.
You can soak linens, even colored embroidered pieces, in this for several days.
As with all linens and vintage pieces, rinse very well, over and over, to remove every trace of soap.
*Important: Make sure to test a small area first before using
Don't Miss These Tips:
Caring For Vintage Quilts: Cleaning & Storage Tips
Grout Cleaning Tips & Recipes
10 Ink Stain Removers – Laundry Tips
