Identify Filter-Flo from Memory
qualin
Sep 24, 2011
1,108
Canada
Hello everyone.
I joined this forum because I have something in my mind which is really bugging me.
Back in 1979 my father found an old GE Filter-Flo washing machine in the Junkyard.
He put two bolts in it and it served us for another 12 years before it packed it
in.
I distinctly remember my father having bolted it to the floor and whenever it went
into Spin, it would make really loud banging noises, regardless of whether the load
was balanced or not. I also remember the lights briefly dimming as it went into
spin. We still have the motor out of it. It does duty as a polisher now.
I also remember my father duct taping the suds saver control because if my Mom
accidentally set it, the machine would flood the basement.
We eventually had to get rid of it due to it leaking, the outer tub had developed a
hole, probably from the repeated banging of the inner tub over the span of all of
those years. :)
Being 16 years old at the time, I had the privilege of taking the washer
completely apart, where I found a missing spring which was connected to a cable
which held the tub in place. However, the damage was already done and the rust was
just too bad. So, the washer went back to where we got it from, probably to be
crushed.
So, here's the thing.. I have no idea what vintage this washer was. I only know
these things:
- Judging by pictures I've seen of other peoples GE Filter-Flo's, the vintage of
this machine would have been between 1962 to 1969.
- I remember that the control panel was battleship grey. The controls had a black
background with white lettering.
- I remember it had the large white toggle switches which were typical of this
vintage and the silver control for the suds saver.
- Had a suds saver control, which I suspect would put it into the Early 60's.
- The suds saver control had a chromed knob.
- I recall the filter which went on the agitator was white and had handwritten
"Filter-Flo" on it instead of just the GE logo.
- On either side of the control panel, were chrome "fins" in an inverted "L" shape.
- I only remember the machine had two cycles, Normal and Permanent Press. However,
my memory may be failing me here. It was a fairly basic machine in this regard.
So, I gather all of you are very experienced and knowledgeable! Could any of you
help me identify what vintage this machine is and if possible, link to a picture
of it so I can see if that's the one?
Thanks!
OK, I'll take a stab at answering your question.  I note that you hail from Canada, so if you grew up there, keep in mind that you may be accustomed to seeing slightly different products that I'm used to seeing here in the states.  But, based on your description I would venture a guess that the machine you're describing was a post-1963 product; probably a '64 or '65.  The console you describe was probably the same as in this photo, although this is a much newer Filter-Flo.  The console shape, layout, template, stamping, whatever was introduced in 1964 by GE.  Prior to that the consoles had a vertical face (not inclined as this one is), the toggle switches operated in an up/down manner, and I am not aware of any rotary switches prior to 1964.  In 1964 this console was introduced and featured toggle switches that now work in a left/right manner (2, 3, or 4 switches stacked on the left side of the panel), sometimes with a chrome rotary-dial-switch that could control water level, or an optional feature such as second rinse (or not) or suds return (or not).  The trim at the end of the console varied between two designs, one of them featured a "flair" at the top, as the trim in this photo shows (that's as close as I can imagine anything close to your "inverted L" profile.  Someone on here acquired (within the past year, I'm thinking) a basic Filter-Flo from the mid 60's that might illustrate the design you're describing, but I can't find the pictures.
Anyway, this might serve to launch a discussion and even photos that might come closer to the answer you're seeking.
Lawrence
Battleship Grey, huh?
Here's a great old 1963 model owned by Mark in Virginia. Fits a lot of points in your descriptions especially the color of the panel and the big toothy toggleswitches. There's a chrome knob in the center, but it doesn't have anything to do with the suds saver. That's controlled by the double-wide white toggle to the left. Gorgeous machine. One of my all-time favorite Flo's. Lighted control panel. Even has a primordial mini basket and what GE described as a "one-shot bleach dispenser".
Thanks Guys!
Thanks Lawrence.. The white switches on the left of your washer are pretty much
the same as the ones on the Filter-Flo I remember.
Baj, The chrome knob in the center is pretty much the same, but that model is
too early.
So, that narrows down the date to 1964 to 1969.
The graphics on the timer knob have the fine lines.. I'll attach a URL..
Similar to this style...
http://www.automaticwasher.org/TD/JPEG/VINTAGE/2011/akronman++2-7-2011-00-34-43.jpg
Getting closer...
Here's a thread I saw which has a lot of pictures which share a lot in common
with the Filter-Flo I remember...
However:
- No speed switches, this looks like it's a higher end model.
- The knobs are bang on.
- The Timer Graphics are pretty much bang on, but there isn't as many cycles.
- No Fluorescent light and wrong background on the console.
So, this narrows it down a bit..
Thanks for all of your help so far!
http://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?31300
Jon Lovitz guaranteed capacity ratings
Yeah, that's what I figured if the '63 example wasn't it. That model is about a 1967, the year GE decided that its 12 lb capacity machine wasn't really a 14 lb. capacity machine, it was, in actuality, a 16 lb. capacity machine (16 lbs. of mixed soaking-wet fabrics); Gansky has a pair. What you're remembering as battleship grey was really a very light tint of blue. The suds saver knob would have been an option and would have been placed in the center of the panel next to the "load select" knob if there was one. These machines, in the US,  usually had a black activator with a green cap and a filter-pan that could have been such a light tint of green that it read white. I've seen Canadian examples of these where the colors were different. I think this machine belongs to Swestoyz.
Another one!
OK, Was doing some Google Fu and found a machine made from May of 1967 in a thread
on here. Shame it needed a new inner and outer drum.
The color on the control panel is wrong, but the feature set is fairly similar.
I do recall that my parents Filter-Flo did NOT have a water level adjustment.
This machine in the thread doesn't have a suds saver. Do you guys know when the
Suds Saver feature was eliminated in GE Filter Flo's?
http://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?19782
Thanks Baj! Getting closer!
LOL! Found the thread the same time you did. Thanks Baj!
That's much closer to my parents machine, but there's still a few differences.
If color was something they did in later models, then that could put it somewhere
between 1964 to 1966 quite possibly.
