Unusual noise on a Norge tag washer
I would agree with Melvin and reply eight it’s likely a bad water pump hopefully so at least, I wouldn’t bother changing the belt unless it looks badly worn in the belt usually will outlast this machine, also, if you find the cost of an OEM water pump to be more than you want to spend. We had very good luck with the imitation Chinese ones on these machines That you can get from Amazon and everyone else. While you’re under the washer, check the motor pulley carefully as well. It’s probably OK but if the pump it started to lock up, it’s plastic and it often starts to melt and that will tear up the belt, and the motor pulley may not be available anymore. If it’s in really bad shape, that might be the end of the washer.
The machine is already 15+ years old and they eventually do have transmission or main drive pulley problems and main seal and bearing problems so it’s not gonna last another 15 years.
John
