Don't some large laundries use co-generation to try to recapture some of the energy? There are also things like using the drain line to pre-warm incoming water. Still, not a place I'd like to be during a heat wave.
My backyard shop has one of those gas heaters with a fan suspended from the rafters. Never had it running, though, as it would be hugely expensive to try to heat that place in the winter. It was built in the 60's, when energy was much cheaper (gas was less than $.50/gallon, as I recall). I suspect the two Miele washers in there will be the sole source of heat during this winter ;-).
