Inlet Filtet SW AWNE92SP113TW01
Slow, cold water fill
Hi Matthew, putting new filters in won’t do anything if the old ones aren’t clogged. You need a new inlet valve most likely I assume you’ve tried taking the hoses off the inlet valve and directing them into the machine and turning them on full force to make sure that the house plumbing and shut off valve is OK.
A slow fill condition is the most common problem with inlet valves, the cold side usually goes bad first because it’s used so much more than the hot side. John
