murando531
Hey all,
I decided, after my WTW4800 having sat in the garage corner for over a year, to try and set it up in the laundry room and have it as a secondary machine. With agitator washers being in hot demand lately and WP re-releasing their agitator models again, I felt it was a waste for such a good machine to just sit idle and waste away.
It's a bit of a cozy fit in the room, but nothing unmanageable, and it's actually not as cramped as I thought it would be. If the CatGenie didn't -have to be- in the laundry room, there would be a nice little square of space free, but that's no biggie.
My challenge now, however, is figuring out the safest yet most economical way to have the second machine hooked up along with my primary washer and the CatGenie. I posted pictures to show the current connections. The CG has a T-connector at the moment that has worked brilliantly, but it only requires cold water. If I have both machines installed, that will be three 3/4in. connectors on the cold side, and two on the hot side. That's where I'm concerned, because I'd love to have Y or possible W(?) connectors with shut off valves, but I don't want there to be too much stress on the main valve fittings. For those who have experience having multiple machines installed, what suggestions would you have for this set up? I'll have to get an extended drain hose, but I don't mind switching them out of the drain when needed.
P.S. Don't judge the dusties in the valve box!! D: It looks way worse on pictures since most of the dust is lightly colored haha!
