I have a 4 quart oil capacity Waring Pro Deep Fryer. Just like two other deep fryers I tried, even though the fryer will indicate that it is up to the selected temperature, it is far short by a deep frying thermometer that I know is correct. For example, if I set the fryer at 375 F, and the ready light comes on, the oil is really about 345 F. I moved the smaller thermostat from where it was attached touching the heating element to between (and not touching) the middle of the heating element, but that seems to have done nothing. I suppose the middle prong coming from the unit is also a thermostat. I think this deep fryer has two thermostats, one for selecting a temperature, and the other for a top temperature cut off. I don't know which one is the culprit.
There are screws in the back of the heating element unit, but I have not looked inside. Do any of you have advice on how I might adjust the thermostat t get it to heat to 375F?
