speedqueen
So I can rearrange the living room to accommodate the Christmas tree later this month I will have to run a cable through two aligned cold air return grates. The problem was that the cable wouldn't fit, so I had the idea to see if I could use two 300 to 75 ohm reverse balons and a length of 300 ohm Twin Lead that could fit between the slats of the air return grate. Theoretically it should work, but I had my doubts as to whether TwinLead could handle the large bandwidth used by digital cable. In the dry run(stringing the TwinLead across the living room) it worked flawlessly and even worked for on demand services.
Here is proof, also this is my "new" TV set, a late '70s Zenith ChromaColor II. It replaced a '90s rear projection set.
