turquoisedude
And I'll apologize in advance for not having more shots of just the machine itself, but I've been having problems with my camera. Hopefully that will be corrected on or after June 5th and I'll have some more complete photos to share...
So, here's the backstory on this one: In February of this year, I had Phil create a diversion at Jon (jetcone)'s storage area near where Rosalie's is made and I whisked a nifty GE AW5B6 automatic washer onto his truck. Then I collapsed with a ruptured gut... LOL
This washer has a lot of history behind it - it once belonged to Robert (Unimatic1140) himself! I may be missing some links in the chain, but the washer found it's way to Beltsville and John (combo52)'s Appliance Museum. Jon moved the machine to Boston maybe a little over a year ago and had it in storage. When he had to relocate a number of machines into a new storage unit, he generously offered me "joint custody" of this GE washer! And as if I was going to say no...
Now, as far as I know, Robert did all the hard work of restoring the machine to operating condition. When I got it, it was working but the original motor-mounted drain pump had been replaced with a separate electric pump. All I had to do was connect this again and I'd be all set.
Me, being me, waffled and hesitated for a good while trying to figure out the best way to install the pump and keep it secure. I didn't want a pump working loose during a spin cycle (nor did Hubby...)
So here's what I had to work with. The tub drain outlet was nice and solid; Robert had figured out how to power the pump which is ingenious - it could be fed from the leads to the reverse winding of the drive motor so that when it went into counterclockwise rotation the pump would get power.
[this post was last edited: 5/24/2016-14:14]
