K A portable DW
"Mobile (has all wheels)
Very old but still works."
Important: It's very, very, very, very, <span style="font-size: 18pt;">very</span> OLD !
It looks as good as new. Look at how clean the top is. The top looks freshly oiled or they put on a poly coating.
All of that "stupid" water heating increases its performance, especially for those who have their water heater set at low temps and/or with long runs to the facet/dishwasher. Honestly, I wish my KDS-18 did that. I was never bothered by them in my KDS-19 or KDS-20 and I had my water heater set at 160F with 150F coming out of the tap. It still heated the water for approx. 10 minutes. Selecting "Heavy Wash" would cut the heating time in half using a quick purge cycle to preheat the interior.
[this post was last edited: 12/30/2021-21:10]
I am glad you are happy with your 19's performance. Heating water to throw onto cold dishes is not efficient. Your comment about the flush feature of the Heavy Wash shows the wisdom of using the heat in the water in the hot water line to prewarm the interior of the machine. This was discovered in the 1950s when manufacturers saw the benefit of adding detergent dispensers which allowed a prerinse or prewash before the main wash which made higher temperatures in the main wash possible.
I do agree it would have been better to run the motor while filling and continuing running an additional 1-2 minutes after the tub is full. Then stop and heat to 150F. Too much amperage draw for most electrical circuits of the day to run the motor and both heating elements at the same time. I'm guessing it would take a dedicated 30 amp circuit to pull that off.
