flyingethan
Active member
Hello everybody. It's been a while since I've posted anything here. I am going to install new bearings, WP8546455, in my center post in my Kenmore 11072693430 this coming weekend. I have the bearings, bearing puller, bearing installation tool and the various seals required.
I want to check the gear case oil level while I have the gear case/ transmission separated from the machine but I am not sure what oil to use to refill the gear case. I am thinking that 85 weight gear oil is appropriate but I would like some expert opinions on what I should use. Also, do you fill the gear case all of the way up with oil or is there a specific oil level that is preferred besides topping it off.
By the way, the bearings that I have are part of a kit. The two bearings are different sizes. Does the larger bearing go in the top and the smaller bearing in the bottom of the base/ sub structure center post or vice versa?
I almost forgot but I have one more question. The clutch has been been making noise lately. It is functioning properly but when the clutch engages to begin the spin cycle and when it disengages it's making a loud clunking sound as if the brake yoke is striking metal when is engages and releases. Since it is functioning just fine I am thinking that there is a part that should deaden that sound (maybe a plastic/ Teflon spacer or snubber or something) that has worn out or something. Any advice on what is supposed to keep the brake yoke from being so loud when it engages/ disengages?
I've included a picture from another forum user of their base for reference concerning the bearings that I am referring to.
Thank you in advance for the advice.
