addle
Kenmore 11087572110 gas dryer coil replacement.
I watched the video below about replacement of the gas valve coils. The video claimed there was an important spacer for one of the coils. When I disassembled the coils on my dryer I was careful to look for the spacer but I did not find any spacer. Is it possible that my dryer does not need one? Why was it designed with a spacer, maybe some valves do not need a spacer? I already ordered the suggested replacement parts but was wondering if y'all think it will work or is it hopeless.
At 4:10 He shows a spacer that I do not think was on my Dryer.
This is the coil kit I ordered.
www.appliancepartspros.com
Whirlpool 279834 Dryer Gas Valve Coil Kit (AP3094251) - AppliancePartsPros.com
The Dryer Gas Valve Coil Kit is an OEM replacement part for Whirlpool dryers, as well as Kenmore and Samsung dryers. It is a set of coils that control the flow of gas fuel to the burner. The gas valve regulates the precise amount of gas needed to properly combust and generate heat for drying...
