drummerboy928
I am the proud owner of a 1983(ish) Kenmore Belt Drive 70 Series washer that i bought about 4 years ago. Over the years i’ve replaced the Pump, Belt, and fixed some rust on the outer tub. Recently (the past four or five months) It’s begun to make a sort of grinding noise when the machine is cold. It only ever makes the noise when agitating, and never makes the noise in drain or spin. However, if the machine is warm, or once the transmission has spun for a minute or two to warm up the transmission, it no longer makes noise. this machine is currently stored in a garage and by “cold” i mean when the temperature is about 50 degrees which is the coldest i usually ever use it. if i put a heater pointed at the transmission or set it to spin for a couple minutes, the noise goes away and does not come back unless the machine sits for a while. I’ve included a link to a youtube video of it making the noise.
