Kenmore Compact Electric Dryer
This machine has the guts of the compact dryer (that would normally fit over the compact washer on a stand or roll around on wheels) in a full height cabinet. See how it does not have the lint screen access door on the top of the cabinet? That is because it has the lint screen in the exhaust port in the rear bulkhead of the drum like the rest of the little 24" dryers. The drum is made to hold the load of the portable washer, so it wasn't made to handle the load from a full height 24" washer, but it is a rare machine and a very well made small dryer.
..the more I think about this dryer, the more I see how it can be very handy. If it runs on 110 it could be a great back up dryer without needing an additional gas or 220v outlet.
Then pair it with the 24" washer and you could have a nice "diaper/pet/shop" set.
..so it's just this model on steriods? These little buggers have been around for ages, so at least your getting a proven design. Parts are also plentiful. Although, not very popular in this guise, as this little one has been up for sale for a few weeks now. Might have something to do with the full-sized price of $100.
Have A Vintage Whirlpool Version Of This Dryer
Would love to find one of the orignal stands, but anyway.
Despite their size the units actually are pretty good dryers, well at least mine is anyway. Better results and less energy use comes from having items either partially line dried or using a high speed final spin. I usually bung certain items into the spin dryer for a few minutes first, especially thick and thirsty things such as towels.
The end of cycle buzzer is loud enough to wake the dead and cannot be disabled on any versions. The one big change over the years is that the compact dryers joined their larger cousins in getting sensors as opposed to just time drying only. One assumes this was done as the cost of such functions dropped and to increase energy efficiency.
I had one of the Kenmore versions for years. Only repair was one belt replacement. I had the 'apartment' washer to go with it. Originally moved the washer to the sink but eventually had it plumbed. I did a second spin for towels or anything heavy. And, yes, the buzzer would wake anything. It was like the Energizer bunny, It just kept running and running and running. It's replacement is a Duet. Stacked washer and dryer and they fit in the same space.
Yes, the photo in #8 resembles mine. I can't clearly see the decorative knob insert or the dial silkscreen so it may not be the same year. Mine is not for sale, I need it. And yes the cycle buzzer will blast you out of your shoes. It only sounds a little over a second, while the motor coasts until the centrif switch opens.
The buzzer can be quited considerably by removing it from the metal panel to which it is attached. Then it does not have the sounding board to amplify the noise and it is almost polite.
The reason the 115 volt dryers got the electronic sensor is the DOE mandate that all dryers have an automatic dryness termination cycle. 115 volt dryers don't get hot enough to do a dependable time/temp auto dry so they put the electronic dryness sensor in 115 volt electric dryers while retaining the less expensive time/temp auto dry system in the 230 volt apartment size dryers.
Compact Gas Dryer
Eric I have never seen the full height 24" dryer in gas but I know they were available, if you buy one of these I can convert it to gas by stripping one of the 3 or 4 gas compact machines we have at the warehouse.
Loud end of cycle buzzer, it always amazed me that they never used an adjustable one as these dryers were almost always installed in the living quarters of homes, it is however easy to just disconnect it of modify it as Tom suggested.
Always seems hit or miss for me. Often one checks a load and it seems a bit too damp still, so reset the timer for another ten or so minutes (before cool down on the "Normal" cycle) but usually when one checks again (after hearing the click that indicates the heating is being shut off for the cool down phase), laundry is usually hot/bone dry.
Have always wondered if the heating power could be increased by swapping out a higher voltage element. IIRC vintage full sized Frigidare dryers that could run on 120v went up to around 1800 watts. Now that would be something.
Nice Set!!!!!!
I have this dryer in white. I will never find the washer!
I can't even find a Hoover Twin tub let alone a MT. I am sooooooo jealous! Been looking for 20 yrs for one!!!
