whirlcool
A friend of ours has a Kenmore dryer:
Model Number: 110 72952100
Serial: ML2908813
The dryer stopped working. His wife said it made a pop noise and stopped. It's a gas dryer. I looked at it and when you turn it on there is no noise or anything, but the dryers drum light is on. I turned the drum and it turned very easily, I suspect a belt. But if it's only the belt, shouldn't the motor be running? In this case the motor does not run when the dryer is turned on.
Also does anyone know what year model this is?
Thanks!
Serial: ML2908813
Thanks!
