Top-freezer, model 253.6580250A.
Need to replace both gaskets. There was no air conditioning run in the house for the duration since it was new, but will be now. They're cracked/torn in a few places, pulled loose from a couple corners, moisture drips from the freezer door if it's opened for a few mins. The unit is otherwise in good condition. Ice maker kit added last month.
Initial investigation finds there apparently are no screws on the gaskets. They apparently press into place, anchor onto keeper rails or some such. This job needs to be done by July 17 but I'm leery to get on it without advice on whether there's a trick to attaching them.
Thanks in advance.
