48bencix
Our 2006 Kenmore Range (Frigidaire) has a control board problem. Door lock light stays on. You can set time but it goes blank. No other buttons work, oven will not heat. When this started door lock was buzzing, I guess trying to lock. We unplugged and plugged back in and buzzing stopped. I took control board out and took it apart to see if I could spot weak solder joints, but no such luck. We can buy a new board but wanted to ask if board can be reset. I plan to unplug all wiring from board and just use the burners temporarily. Used board is about $90 and we can get a newer range on Craigslist for about $200.
