Kitcheanaide/Whirlpool Washer Making Grinding Noise
hemjs01
Jan 20, 2022
2
Glenview
Please review my video:
It works great but makes this incredibly loud grinding noise. It also doesn't really agitate - I checked the dogs are in good shape.
It is a direct drive KAWS750LQ0 circa 2002.
I've torn the machine apart and check everything. I'm boiling it down to either a bad transmission or potentially a bad capacitor (although it has continuity so it's charging and discharging).
Any help/advice would be appreciated. Thanks
Mike
Interesting that the noise occuring during spin doesn't begin until after the basket is accelerated to full speed.  The agitate shaft disengages during neutral drain and spin but the rest of the internal gears continue to oscillate with the same motions.  May be a problem with the cam on the agitate shaft.
When you say pump? I would assume you mean the white water pump attached to the motor. I did clean it out and it appears to be working because the water in the tub is draining properly.
Thanks John L. That's what I was thinking but I wanted to get another opinion. Took the agitator assembly out so that it was strictly motor, drum and transmission. And the result was still the same. The motor works fine and was quiet when operating independently. I doubt its the drum bearing otherwise it would make that noise all of the time. Therefore, I think it's time for a new washer......transmission is like $200 - too expensive t repair this 20 year old washer.
Not if you want to have a better machine than anything new, other than perhaps Speed Queen.
A few (not all) of the transmission internal parts are available, depending on what's causing the problem ... if you feel up to opening it up for examination and possible repair.
Corecentric (a rebuilder) is offering refurbished transmissions on Amazon for $126 plus sales tax, free shipping.
A couple other sources are $144 and $151, both plus shipping and tax so that does put it upwards toward $200.
