frontloadfan
I have had my Kitchenaid FL washer a week now. I wanted to go ahead and start a thread about this machine. As I have more experience with this machine I will add.
First of all a big drawback to this machine is that it is very hard to actually see one before you buy it. I live in the San Francisco Bay Area and I went to all the big box stores and none had the Kitchenaid FL on display. In addition, check out this web site and there are no postings about this machine either. What finally pushed me toward this machine was the forum on Consumer Reports On Line. There I found a thread from a dozen who actually have this machine and since there were no horror stories, I took that as a good sign. In addition, I was able to view the machine on both Kitchenaid's web site and Consumer Report had a picture of it too (with a comment about how stylish it looked).
First the machine I am reviewing is the model # khws02rmt. Last I looked this is the model featured on the Kitchenaid web site. However, I talked to the Kitchenaid consumer 800 number too and I learned that they are now producing a new version of this machine that has at least two revisions. The new version has increased the RPM spin from 1250 to 1300 and has added the Bulky cycle. So if you do order this machine, make certain of which version you are getting.
Moving on, I had two options for color: Meteorite or White. There was a $100 difference in cost for the Meterite. It was well worth it. It is described as "new matte, metallic finish . . . that hides fingerprints and won't compete with the decor in any area of the house." Make no mistake, this is one beautiful, upscale looking machine. The door and the controls (using metal rather than plastic for the controls). This machines appearance coupled with its upgraded sound insulation make this machine perfect for anyone who needs to have the machine in a living area.
The biggest disappointment in this machine was a missing feature. It does not have a delay wash function. This really surprised me that what is considered a upscale machine would not have this feature. It does have a unique option that may give someone a time delay feature. You can set the machine to whatever cycle you want and then push an option button call "Rinse Hold". You go about your business. The machine will run whatever cycle you programmed. You come back home and the machine will have stopped just before the final rinse (as I understand leaving your clothes in rinse water). When you arrive back, you go to the machine and push the "Rinse Hold" button. As soon as you do so, the machine will then complete the final rinse and then the spin. It is a nice function, but I wouldn't say that it is a great replacement for "Delay Wash".
The machine lists as having 12 cycles. Missing from it cycles are two that are found on the Duet. In case you don't know, the Duet and Kitchenaid are both made by Whirlpool. The two missing cycles are "Active Wear" and "Bulky". As I mentioned above, the just released version of this machine is suppose to have the "Bulky" cycle.
Cycles:
Sanitary, Whitest White, Heavy Duty, Rapid Wash, Delicate, Silk, Wool, Handwash, Soak, Rinse/Soak, Drain/Spin.
Options:
There are 4 options available. They are: Rinse/Hold (I already described this option), prewash, auto soak and extra rinse.
It is interesting as you don't have total freedom to use the options. The four longer cycles (Sanitary, Whitest Whites, Heavy Duty, and Normal Casual) are allowed to have any of the four options you may wish to have. I guess there is some sense to this. I mean you program that you want a rapid wash, so it wouldn't make much sense to have a prewash. In addition, you can never use both Prewash and Autosoak for the same load. You can have one or the other but not both. There is logic behind this as they both use the same detergent slot. Also you should be aware that you are going to use the autosoak, you need to use powder detergent for the main laundry detergent slot as otherwise liquid detergent would seep out during the autosoak.
For water temps, you have the option of
Super Hot/cold
Hot/Cold
Warm/Warm
Warm/cold
Cold/cold
You need to be aware that with some cycles, you don't have the freedom to reset the water temp.
The manual that comes with the machine is really good in that for each of the cycles it tells you the suggested load type for each one PLUS it tells you briefly what the machine will be doing different for this cycle. For instance, the Whitest White includes an additional rinse to make certain the bleach is all rinsed out.
Water temps are as follows: Super Hot is 153; Hot is 122; Warm is 104; and cold is 77.
Inital reaction to this machine is that it is a beauty in terms of appearance. It can't be beat for being so quite. Whirlpool uses the standard sound insulation as they do for the Duet and then for this machine they reconfigured the water exit hose to cut down on the noise additionally.
With the Kitchenaid you get a two year warranty.
My two previous FL machines had spin maximums of 900 (Frigidaire FL) and 1100 (new Maytag Neptune). It is amazing how much faster 1250 seems! I ran a really clunky load. The machine itself took the load in stride, but once it kicked up the final rinse speed, you could feel the floor vibrate and the dryer vibrated too! The Kitchenaid just took it in stride. I know with my Neptune (that I had for all of a month), it really seemed to balk at small loads, like it couldn't adjust to having a small load to spin. This machine doesn't seem to have that problem.
Any case, this is just a first posting. After I obtain more real world experience, I will post back!
Cycles:
Options:
Super Hot/cold
Hot/Cold
Warm/Warm
Warm/cold
Cold/cold
