Kitchenaid Hobart KDS19 leaking washers/ gaskets needed
karma2021
Member
Apr 20, 2021
15
Rome, GA
Our Hobart Superba KDS19 has a small leak coming from the top of the motor. It is fine mist leak on the top of the motor when something plastic (impeller?) is spinning.
Is it possible for me to fix this leak? I am not an expert! This forum's members have helped me twice before to keep our dishwasher going.
I have parts and repair manuals. Parts and repair advice welcomed. There are lots of washers and gaskets listed above the impeller on the parts diagram. It's rather intimidating to me. Thank you support members.
You need a seal and impeller kit.
https://www.ebay.com/itm/286619391649
CAUTION!!
When disassembling, you will come across spacing washers on top of the drain impeller (properly spacing of the wash impeller) and washer(s) under the drain impeller (proper spacing of the drain impeller). Carefully remove these and separate them so they don't get mixed up. If they are mixed up or lost, you WILL have a leak and require the impossible to find gauges for proper spacing. When reassembling, install the washers back in the same exact locations and orientation. Doing this will allow you to skip the spacing process.
img20251109_13234626.jpgimg20251109_13260480.jpgimg20251109_13273541.jpgimg20251109_13285011 (1).jpg
CAUTION!!
View attachment 320732View attachment 320733View attachment 320734View attachment 320735
Thank you for the advice and cautions. I have ordered the part. I will strap on my courage and give it a try to do the repair. K
Good news and Bad news:
I installed the new parts today and it did not leak. I felt pretty accomplished.
However a problem occurred and the pump started making an alarming sound during a second test cycle. I canceled the cycle.
The water would not pump out. I investigated...and the key nut on the top impeller had shifted. I know I did not install the spacers in the wrong order per your warnings. I put the key nut back in alignment and (leaving the spacers in place) re-tightened the screw on top of the impeller.
Put it all back together but now I am afraid to re-test.
Not sure what is wrong, but I think I am giving up
What should I do?
The key washer?
Make sure the key washer is properly indexed, it may have not been indexed or seated properly and shifted. The impeller retaining screw should not have backed off, it may have been loose or became loose if the key washer shifted.
What should I do?
It's probably fine now that everything is lined up and tight. If all of the parts in the proper order as pictured in the scans I posted, you won't hurt it.
The key washer?
Yes, the key washer. I just removed the cover and gave the screw more torque and made sure it was seated properly. I was probably too cautious first go around, fearing I would flatten the spring washers and mess up the spacing. Well that backfired! I will run it again in the morning when I have good light. I will give you an update tomorrow.
Would it not pump out because that impeller was loose?
The motor sounded very different, too...
Make sure the screw for the spring washers is tight. Not so tight that it strips the screw, but definitely tight. You won't flatten out the spring washers, don't worry about that. The screw needs to be tight for the spring washers to properly do their job and the key washer to stay firmly in place.
Okay qud-dan
You have been invaluable to my KSD19 leak repair attempt.
Report and question:
I went back into the dishwasher today and the key nut and impeller screw were tight, but the key nut had shifted out of the groove so it was not indexed and I had a tough time getting the screw to come out with the key nut spinning. I saw that the shaft had rotated and I could not index the impeller properly. I twisted the stem a partial rotation for proper seating of the impeller and key washer. Put it back together.. Now it will completely wash, pump out and the motor sounds normal again.
Unfortunately now I have a 2 small leaks Right and Left of the motor. And it was yellow colored liquid. Do you think spacing may have gotten messed up when it was free turning without being locked into the impeller?
I think the leak may be from the previous attempt if it's yellow. These machines will leak a bit after it's put together correctly from a previous leak/incorrect assembly. Run it and keep an eye on the leak to make sure it's not continuing or getting worse.
