I own a Kitchenaid Dishwasher KUDA22ST3 with a motor - pump issue.
I need to 'bench test' the motor - pump but do not know how to do that (see below)
a. It's touch control panel is functioning normally.
b. The motor - pump assembly is Whirlpool - Kitchenaid part # 4171577
c. The Kitchenaid (Hobart?) motor alone is part # 970949
d. This motor has a relay but no external capacitor.
Here's the problem:
When starting the dishwasher to either pump or reverse pump (drain) there's a BUZZING for 15-30 seconds, no motor rotation, and then silence (?thermo protection). I cannot restart right away (?thermo protection) but waiting 15 minutes it will BUZZ again with any attempt to pump/drain.
I bought a used motor - pump assembly and used relay which reportedly were functioning.
I first replaced the motor - pump assembly and the same issue reoccurred.
I then replaced the relay (which moves-rattles freely) and the same issue recurred after trying to pump/drain.
Is there an easy way to bypass the upstream controls and test the relay & motor - pump?
I believe I either have two failed motors or something upstream in the controls failing.
The thread in the link below concerns replacing the same motor - pump assembly 4171577 and helped me get this far.
http://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?37129
Thanks for your time and attention.
Tom Schwab
Rochester MN
Here's the problem:
Tom Schwab
Rochester MN
