peterh770
The bf has this great KM/WP dishwasher that has developed this issue recently:
Start dishwasher, usually the sensing or the normal cycle
Fills and starts to prewash
Sense pause
Prewash continues. After a few minutes, you hear the recirc pump starting to suck air.
Sense pause
More washing, more and more air sucking.
Drain
Fill and starts main wash
All good
Sense pause
More washing, but after about 5 minutes, starts sucking air again.
Sensing pause
More washing with more and more air sucking.
Here is where I start to get concerned, because "hi temp" is selected, and if the water level is getting lower and lower, could it overheat, melt things, become a fire hazard?
Sensing. How can it sense with so little water in there?
By the end of the main wash, it is dry.
It doesn't have this problem with the rinsing. My guess is because there is no sensing pause during them. The first rinse is short, but I would not call it a purge. The last rinse is VERY long, even without the "sani rinse" selected.
Is something happening with the flapper valve when the machine pauses to sense? Is the drain pump running the entire cycle, or is water slowly siphoning out? The drain hose does a high loop to the top of the cabinet before hitting the wall drain.
When it first started this, I took the wash arm assembly apart and cleaned out a couple of screws, broken glass and twist ties from the sump. I cleaned the screen and got rid of calcium deposits. The flapper valve was intact. It seemed to help the problem, but it is still happening. I could find no YouTube video for this problem.
Pics to follow (with model sticker).
Sense pause
Sense pause
Drain
All good
Sense pause
Sensing pause
