KM wringer Qs
cfz2882
Feb 9, 2010
2,632
Belle Fourche,SD
got a late '50s era kenmore wringer this past weekend-its in real decent
shape except the motor is missing,6A on the nameplate so looks like originally
had a 1/3HP?Model 110.5902802,ser c83306-(1958?) hoping it is from '58 and
uses a 1/3 hp because i have a 1958,1/3hp,"packard"motor that may have found a
home in this washer.
So far the only mechanical problems evident are a gummed,stiff pump bushing
and a hard,glazed pump drive tire(luckily that wheel was in the tub)
the ribbed,brown rubber hose is quite stiff too.This wringer even has a lint
filter-drain hose fits into a hole in the lid that underneath has a clear
plastic cylinder with a nylon brush inside to collect lint.
It is a 1959 model....
You can tell because the first to digits after the 110. designate the model year...PAT COFFEY
